Oem TPS ?
1GR8M56S
Car: 2013 M56S
Im about to purchase a set of oem wheels that come with tires and tps, do I have to program the tps's to my car or will they just work?
Debonair
Car: 2011 Infiniti M56
They have to be programmed.
Ilya
I dunno...my aftermarket TPMS did not need to be programmed when I moved the wheels from my 07 (traded in) to my 11. It picked right up. They were ones TireRack installed in the wheels/tires when I got them. At least I do not remember ever having them programmed...
Debonair
I have three used OEM and one aftermarket in my new wheels. I definitely had to program them when I installed them. There is no way for the car to recognize them without it being told to look for the sensors being put into a discoverable mode first. You need a capable scan tool and a hand held TPMS tool.
Also, the 2011 and newer M's got a new sensor that is not compatible with the older ones. I had to make sure I got the correct ones when I was preparing for my new wheels. Maybe the aftermarket sensor work with both systems.
1GR8M56S
Car: 2013 M56S
so if the (OEM) rims and tires are from the same year body style and model car I would still need to program the tps?
DoN_BLaZe34
Car: 2007 M45 Sport - Sold
2006 FX45 - Traded
2014 Q70S 5.6 - Sold
2017 Q70L 5.6 - Current
I recall the older sensors would recalibrate after 100 miles or so, at least they did so on my M45. I've never had that luck with the newer ones.
In summation, yes, they'll still need to be reprogrammed. The sensors have individual serial numbers that need to be registered to the car, regardless of them being from the same year and model.
1GR8M56S
Car: 2013 M56S
Do I have to get each serial number off the tps then or does the programming machine do it automatically?
Debonair
1GR8M56S wrote:Do I have to get each serial number off the tps then or does the programming machine do it automatically?
They are electronically read as part of the registration (programming) process.
CRV_33
Car: 2011 Infiniti M56x
I bought a set another set of wheels for my M and it had rubber valve stems instead of the TPMS sensors. I went about almost 2 weeks until the TPMS light notifaction on the dashboard finally went on.
