OEM toe and ruca adjustment bolts. Replacement options?
Didderson
Car: 1990 Nissan 240SX FB
'88 Nissan Hardbody pickup
'74 Datsun Z
I'm installing aftermarket rucas and toe arms for the rear and wanted to know if anyone else ditched the stock bolts that adjust the ruca and rear toe arms in favor of decreasing the chances alignment gets compromised over a bump in the suspension.
I always assumed these bolts were why alignments got thrown off in the first place, but if you have replaced these oblong bolts with something that keeps the arms more in place (probably with a large washer to center it in the hole) feel free to let me know your solution!
DrJuice164
Car: 04 G35 Coupe
That is a good question. I am in the same situation, I set both of the adjustment bolts to the same position on both sides and then just had my buddy align them using the arm adjustments.
