DirtyLatte wrote:I was wondering if a Sentra or Altima might share the same rims.
The stock wheels are 16x6.5" +40mm offset, 5 lug on a 114.3mm bolt circle, 66.1mm hub bore.
AFAIK, the only other Nissan that uses the same identical wheel is the '04-'09 Quest.
The Altima 2.5S uses a similar 16x6.5" wheel, however the offset is 45mm. I DO NOT recommend running one 45mm offset wheel with the remaining 3 at the stock offset at 40mm. If you want to go this route, swap all 4 wheels (I do this for my winter tires which are mounted on Altima steel wheels).
Forget the Sentra, it's a 4 lug bolt pattern.. won't fit.
