retho78 »
https://forums.nicoclub.com/retho78-u259735.html
Wed Feb 03, 2016 5:59 am
Hi,
I wanted to know if anyone has replaced the OEM speakers. I did some search here and found some information but it was not that clear.
I have the non-bose system, base model and wanted to upgrade just the speakers with very less modification. I was wondering if I can buy some used bose OEM speakers and use it with the non-bose system, will it work fine, any issues or should I go with some aftermarket ones and do a little modification to get it fit correctly? If so, what brands would you recommend? Also, I saw some on ebay for the nissan bose speakers that look like exactly the same as the Infiniti bose ones but some of them have different part numbers and some don't, wondering if there is any difference? They all say 6.5 inch and have the 3 hole mount clip.
Thanks is advance.
