smockers83 »
https://forums.nicoclub.com/smockers83-u49766.html
Wed Dec 05, 2007 9:38 am
You definitely can upgrade. You have a few options. You can just upgrade the speakers the way you mentioned. You could add an amp or amps to it, that'll get you more power and better sound. You could also add signal processors that take the signals from the factory unit, as they are usually not quality for aftermarket systems, and remove the factory EQ settings so the amps get a good, flat signal, and then you can do sound shaping with your amps for quality sound. There is the mentioned JL one, but I feel the Alpine one (PXE-H650) would be much better, although for $100 more. You have more options, more customization opportunity (a remote allows you to control volume, fade, balance, the subs, etc) and more outputs to allow you to have a bi-amp system for the front components, if you so choose, but if you buy components with an outboard processor, you can skip that option. Both units allow you hook up an auxiliary source, too. Both of these units are at Crutchfield, and I recommend going there just to do research on anything else you plan on buying.
