Postby
r34 gtr »
https://forums.nicoclub.com/r34-gtr-u3863.htmlTue Feb 27, 2007 5:15 pm
no. sorry, but the difference in bores would make this impossible stock, and totally not worth it with machine work. the ca18de ones work, but are 9.5:1 and will require precise tuning. you could ask around, as im sure someone has a set you can buy.
Postby
Masterdebater »
https://forums.nicoclub.com/masterdebater-u30683.htmlTue Feb 27, 2007 7:16 pm
the shop i go to and got the motor from work alot specifically for 240sx's so im sure they know what would work. the sr20 ones i may have heard him wrong thats why i said i wasnt sure but the vg30 pistons fit.
Postby
codyisbad »
https://forums.nicoclub.com/codyisbad-u31107.htmlWed Feb 28, 2007 4:25 am
So... the short answer seems to be no unless I want too high comp ratio. The reason I ask is there is a swap on ebay the guy is selling with low compression. I know the head gaskets sometimes let go but all the numbers he gave me are pretty low and uneven so I doubt the gasket blew on all 4 cylinders. I just wanted to see what was available if I do buy it and it needs a little more than just rings. Any thoughts or input on this engine and what it might be or if I should just stay away all together. I did ask, and there are no holes in anything or signs of massive failure.
Modified by codyisbad at 4:58 PM 2/28/2007
Postby
Masterdebater »
https://forums.nicoclub.com/masterdebater-u30683.htmlWed Feb 28, 2007 11:38 am
ok r34 u win i guess :'(but like i said i couldve been given wrong info.one guy was saying he was running vg pistons in his ca. i dont believe he got it bored out either...ill check back with him to see what he used for sure and get back with yall sry r34 i wasnt trying to sound like a know-it-all
Postby
r34 gtr »
https://forums.nicoclub.com/r34-gtr-u3863.htmlWed Feb 28, 2007 12:48 pm
dude dont even worry about it, no need to apologize. just sounded like shady advice you were given, and i wanted to make sure. i dont know everything either.
cody, it depends on the price i guess. might be worth the trouble if its cheap, but there could be a lot of things wrong.
Postby
codyisbad »
https://forums.nicoclub.com/codyisbad-u31107.htmlWed Feb 28, 2007 2:58 pm
The price is seems good, he wants 400 + shipping. Which in total seems about half of what I have found anywhere else, unless Dee gives really good deals. The comp numbers were dry ranging from 60-100 which basically lets me know that all the valves are still there and there aren't any pistons with holes in them.
