OEM or NGK spark plugs?
dfw240_EE
Car: 1992 240SX
1992 Nissan 240SX
I know that OEM spark plugs are actually NGK's but my question is this:
On a perfectly stock KA24DE is there any good reason to buy the special "V-Power" NGK plugs or do the OEM NGK's from dealer or wherever work just fine?
rsmithdrift
Car: 1993 240sx fastback se.
If you have a otherwise stock ignition set up they don't make any difference whatsoever. Just use NGK plugs and 8mm wires and your good to go. I've used both and feel no difference at all.
180fan
Car: 89 fastback
the v-power seems to add a bit more pep but that could have been a placebo effect. Worth giving it a shot since it's not alot of cash anyway, otherwise go with tried and true normal coppers. NGK's of course. Have you tried sparkplugs.com?
ricebike
2002 Quest
2005 Altima
werd, as long as u stay w/ NGK brand... u r good to go. NGK covers ~85% of the import OEM specs anyways
not that much of a difference if you look up the part numbers. http://www.ngk.com/sparkplug411.asp?mfid=1
scroll down to the bottom on the left side for numbering system.
dfw240_EE
Car: 1992 240SX
180fan wrote:the v-power seems to add a bit more pep but that could have been a placebo effect. Worth giving it a shot since it's not alot of cash anyway, otherwise go with tried and true normal coppers. NGK's of course. Have you tried sparkplugs.com?
I live about 5 minutes from Courtesy Nissan, and I was just going to buy them from there. They are selling the OEM ones for less than Sparkplugs.com or SCO. Besides, I try to avoid buying over internet with a credit card as much as possible. Though I am going to buy my wires from either Sparkplugs.com or SCO. Probably the NGK wires from SparkPlugs.com since they are offering the better price.
