OEM Nissan A/C fittings and conversion for custom setup
Darius
Car: RB25DET S14 - 665 WHP (SOLD)
I didn't know where else to ask this question but I figured the Nissan mechanics would know this best. I have an RB25 swap and want to make custom lines from the high-pressure side of the RB25 compressor to the condenser and from the low-pressure side of the evaporator to the low-pressure side of the condenser. What is the name of the hose ends to each since they are weird, non-threaded, o-ring type things that are fastened with a nut? I'm 99% sure that they're the same size as the 240's. Can I drill and tap the fittings so I can run aluminum or steel fittings with SS braided line or will it leak the R-134 out?
Another option is chopping the fittings off of the old lines and welding them to new lines, but that might be a little ghetto for my taste.
Any help would be greatly appreciated because that is the only thing between me and cold air next summer.
Darius
Anyone.....anyone....Bueller...Bueller
