2008 m35x..
jonlex99 wrote:Guy it is possible that the OP's M has an aftermarket remote start that is program to activate using the door lock signal. This devices can be configure with a double pulse or threeple pulse signal.. Double pulse signal would require the press and depress of the lock button twice back to back. And the threeple pulse would be three times.... It would had been great to have had this feature in the M.
06M4.5 wrote:it's an aftermarket add-on. anyone can have it. The problem is the range is only as far as the remote will work which is not very much.
DeanM45 wrote:I'm referring to minus' post:
Naw...its not aftermarket....its all factory,...when i pop the hood it says its installed with remote start on the guards
DeanM45 wrote:OK, it's an aftermarket system made by DEI that operates through the factory fob.
Good deal.
