Grimy wrote:I feel like my Rogue's lights are not as bright as they should be or once were. I have had the Rogue since November 07(4+ years).
Both HID and Halogen lamps experience a decrease in light output as they age. Both the number of starts and total operating hours affect how quickly the light output deteriorates.
Simply swapping to a brand new bulb (HID or halogen) will result in increased light output similar to what the vehicle had when new. For that reason alone, a bulb replacement is a good idea.
I typically replace the halogen lights on my vehicles every 2 years.
I like my lights to be extremely bright WHITE light..not blue.
Lighting color temperature measured in Kelvin. Example:
Daylight = 5000K and higher
OEM automotive HID's = 4100-4300K
Halogen lights = 3000K.
As you go higher in termperature, the light goes more blue in color. Conversely, lower temperatures are more yellow.
You can select a different color temperature based on your preferences. In your case, I would stay towards to the 4100K range to reduce the amount of bluish light.
As for bulb quality, IMHO any of the reputable mfg's should be about the same: GE, Sylvania, Phillips, etc.
STAY AWAY from any of the unknown brands and any 'fancy' bulbs claiming increased light output. Many simply market high Kelvin bulbs (very blue light) to unwitting consumers who don't know any better! In many cases, they aren't any brighter... and sometimes the visible light they produce is worse!
