NJGuy »
https://forums.nicoclub.com/njguy-u191160.html
Fri Jan 06, 2017 10:42 am
I think it's possible, but definitely not plug-n-play (unless you actually buy the Xenon headlight assemblies). I'm not sure how knowledgeable you are about lighting modifications, but at least to me it appears that it may take a bit of work to get the OEM Xenon components both integrated with the halogen assemblies and keeping a stock looking appearance.
It looks like the factory headlight housings would need an adapter or have to be modified to take a D2S bulb instead of the H11 Halogen bulb. I would think that OEM ballasts and igniters could be used as well, but they may require some custom wiring work or having a harness built. I haven't personally seen the OEM ballasts and igniters, but the ballast might acutally be mounted outside of the headlight housings.
I don't know which model year you have, but I'd start looking at the exterior lighting section (EXL pdf file) in the factory service manual to get a better idea of what you're dealing with. And if you haven't already done so, you may want to check with some automotive lighting modification shops in your area. I'm sure they'd do a much better job of answering your questions than I could. You can also check out the forums on HIDplanet.com.
Most of us here who have done a DIY HID install have used an aftermarket plug and play HID kit due to ease of installation. There may be one or two members who have gone through the process of removing and taking apart their headlight assemblies themselves. And a while back, I think another one or two guys here have had their headlights upgraded by a custom vehicle lighting outfitter.
