oem fogs wont turn on
michael_grigoras
Car: 1991 nissan 240sx
1987 bmw 320i
1983 toyota starlet
1977 mercedes 240d
Alright just recently bought the oem relay and fog light switch i checked the relay working perfectly. fogs were working before i installed the hid 6k kit. after i installed it i only get 10.8 volts to the relay which is 12 volts thus not switching on the fog lights. is there anyway other than taking out the hid kit to get 12 volts to the relay? Or will i have to wire it from scratch? thank you for the help!
compactfean
Car: 89 240sx s13 sr gt3071r 23psi
B14 sentra ser sr20de-t 7psi
daily
Id just wire it from scratch or at least fix the one wrire having the voltage issue. You have 10.xx v going to the fog lights or going to the relay for trigger?
michael_grigoras
1987 bmw 320i
1983 toyota starlet
1977 mercedes 240d
10.8 going to the relay also the fog light button turns my hids to high beam and when high beam is on you can switch it back to low unless it is turned off completely then
turned back on.
