philipa_240sx »
https://forums.nicoclub.com/philipa-240sx-u68765.html
Tue Dec 02, 2008 2:36 am
The first set are made by Hella, but appears to be thier "Optilux' line which is lower quality IMHO. Real Hella lamps are much more expensive.
The second set is some no name I have never seen before.
The differences?
I have used a couple of fog light sets: The cheaper brands tend to have poor construction, flimsy hardware, and just don't last. Expect 1-2 years out of them. Even less if you live in a cold snowy climate. The housings will rust, they'll collect water, and eventually fail. In addition to the lights, you will also need the OEM turn signal lever with the fog light switch, and fabricate your own mounts. The OEM units mount directly to the bumper fascia, this is not possible with some aftermarket lights.
FYI: The OEM fog light opening is slightly oval and slanted back towards the wheel. The diameter is approx 70mm or 2.75". Lights that 'may' fit the opening include:
- Hella Micro DE series- Optilux 1000 and 1100 series- PIAA 1100x and 004xt
I had the OEM Nissan fogs on my Altima. They were in the car for over 4 years with no problems. Expensive, yes. But they really are plug and play. In contrast to some aftermarket kits, the housings were made of glass and impact resistant plastic, the mounts were very solid, and the housing has vents to prevent condensation buildup.
