so thats the only thing you need to make the wiring harness work for the oem fog lights is that switch???mcsniper703 wrote:do you still need combo switch fog? I have one brand new if you want it, im selling it for $60.
Most likely: once the switch is installed, the circuit for the fogs is complete-meaning power can be sent to them when the foglamp switch is turned on with the headlights on. The thing is, on some cars the BCM (Body Control Module) may not be configured for the foglight option, so you may need a Nissan dealer to turn it on for you with Consult III. Not always the case though. Most of the time you install the switch and they work.CaseyLion wrote:
Altered wrote:Most likely: once the switch is installed, the circuit for the fogs is complete-meaning power can be sent to them when the foglamp switch is turned on with the headlights on. The thing is, on some cars the BCM (Body Control Module) may not be configured for the foglight option, so you may need a Nissan dealer to turn it on for you with Consult III. Not always the case though. Most of the time you install the switch and they work.CaseyLion wrote:
I agree with Andy, buy the kit from Nissan. I did it on my L31 in '05 and it worked flawlessly, even with aftermarket Xenons installed.
