OEM color 19" 5 Dbl Spoke Rims
Shocks, springs, sway bars, coliovers, bushings, brakes, wheels, tires - This is the place to discuss G-Series suspension modifications!
hwayne1
The 19" 5 double Spoke Rims on my 2005 G35 Coupe show some wear.I would like to touch them up. Has anyone any ideas on how to match the color? I've researched the forum and seen that some of you had painted the rims.Mine are not in that bad of shape. I'm looking to do some spot touchup.
-Wayne
Rex
Car: None
I've read a couple posts (can't find them at the moment) that says the paint has some lead content, thus you'll almost never find an exact match here in the states.
pfarmer
Car: 2008 GXS with technology package
Rex wrote:I've read a couple posts (can't find them at the moment) that says the paint has some lead content, thus you'll almost never find an exact match here in the states.
If this is the case then one should keep in mind the proper methods that should be used when dealing with lead paint. It may be a far bigger issue beyond color matching.
Perry
joe603
Car: 2014 Durango R/T
A good paint/body shop should be able to get you some touch up...
hwayne1
Joe: Thanks! Matter of Fact...My vehicle looks identical to the one in the photo!-W
Return to “G35 and G37 Suspension, Brakes, Wheels and Tires”
