lol, thanks guys. I had the local nissan order the bolt for me and it came in 2 days.dantech wrote:
Neejay wrote:
I'll keep you guys in mind later down the road, thanks.
Yeppers, we do.nismostate wrote:you guys don't happen to sell sr20det gaskets do you?
Sorry, no 180 stuff.nismostate wrote:I tried to find the sr20det valve cover gasket but couldn't. Also, I want one of those Nissan hats!!
Sorry, no 180 stuff.180fan wrote:how about the gasket that fits between the collector and the runners for the s13 sr20det?
Which one of these brackets is the longer one?Neejay wrote:Hey Dan, do you have the radiator support bracket that goes up top and connects/bolts onto the stock intake tract? I need that one, the longer of the 2.
EDIT: Based on your website, I think its called the "Radiator Mount Bracket" Seems like its $6.40, and I think I need the upper right one. Just need someone to confirm it.
Modified by Neejay at 4:21 PM 11/7/2004
If thats like being in the cabin, then its the one on the right (red) 21560Q I think is what it readsdantech wrote:
Order placed. Thanks a lot!dantech wrote:
Yep. It's $6.40
The number is 21543-35F01. If you do a search for that number from the main page, you can add it to a shopping cart. Thanks
http://www.nicoclub.com/zeroth...ge=10turtl631 wrote:I'm trying to find the 2 bolts on each side that attach the caliper to the hub assembly. They are called "torque member fixing bolts" according to the FSM. I need all 4 replaced due to corrosion...can you give me a part number and/or price? [email protected] keep trying to use this "search 6 million parts" thing on all the nissan dealer sites but I never find things like this. Thanks,Ross
fer what?Tech12 wrote:How about a hicas power steering high pressure line for the front wheels, or the rear bolt that secures the pump in place after you have tensioned it?
Which year? Is it 4 wheel steering or two? Which engine?Tech12 wrote:whoops. s13.
I'm terrible. I was pretty sure that the only HICAS models were the s13 with a KA24DE engine and 4 wheel steering, so thats what I need.Tech12 wrote:How about a hicas power steering high pressure line for the front wheels, or the rear bolt that secures the pump in place after you have tensioned it?
We have a bunch of places that repair those type of hoses here in Phoenix also. They are sometimes companies who repair hoses for washing machines. Same fitting type as an AC or PS hose. Go figure.Tech12 wrote:Wow 76 bucks! Thats pretty 'spensive. I've been hearing rumors of a hydraulics company around these parts that can re-manufacture High pressure lines like mine ... Problem is, I can't seem to remove the bastard.
How about the bolt that keeps the rear of the power steering pump secure? On the hicas pump, there are two bolts that keep the pump in whatever location you tension it to. One in front thats actually adjusts the tension, and anotherone in back that keeps in there. I need the one for the back.
The bolt number is 01121-02091 and the nut number is 01225-00161. You can do a search here: http://www.trademotion.com/par...gid=0 and add them to your cart. Let me know if I can help anymore.Tech12 wrote:I need the one highlighted in green. Can't read the number, but I'm pretty sure that's what I need. Woulden't mind getting 11935C either.Thanks-Lech
