I've found myself in a little jam here - I'm just going to lay out the whole situation here with as much details as I can muster to give context and I invite any and all input/suggestions/thoughts/considerations/insights. Thank you so much in advance for taking the time to read and to discuss this issue with me. And please if this issue has been posted elsewhere direct me there (as I was not able to find anything with my initial search)
2007 Nissan X Trail 2.5lt engine - intermittent stalling while driving (dash lights come on, engine dies - put in park, turn off engine, say a prayer and restart with no issue), engine light come on with codes PO335, PO725 and PO113 - changed camshaft sensor and crankshaft sensor with aftermarket parts (please note I bought a second crankshaft sensor incase the first one was faulty and it wasn't). Stalling issue seems to have resolved itself but now hesitation starting, cranking lots before engine turn over. First start, lots of cranking, turn off and try again and smooth as butter. Once running, shes a beaut.
My main question is, are there people out there that could verify if these sensors are better with OEM parts rather than aftermarket or do we think the issue is deeper and perhaps related to suction valve pump/wiring in the harness/wiring overall or something more?
Without taking things completely apart - visually it doesn't look like there is wire damage but I don't have the scanner or better tools/equipment to test further - I've been recommended to take it to a dealership for them to use the break out box to test connectivity with the circuits. (my nearest dealership is 1.5hrs away
