any1 have an answer to this?elwesso wrote:Sinces its all line level (RCA-ish) couldnt you just buy a line driver to turn up the gain a little???
Where was this discussed? The issue is his old system had "power" in the HU and the new HU doesn't. You could use a gain, but it won't "boot" th esound enoug, that's goig to require actual amplification.elwesso wrote:... personally it seems stupid to get an amp, amplify the signal, then bring it back down...
It is and it isn't. In the "it is" category, much like Maxima's and other Nissans offered Bose & non-Bose, which is what he's combining you can't just plug and play. In the "it isn't" category, the Q and most Infiniti's didn't offer Bose or non-Bose, so the compatibility between them is greater.elwesso wrote:...I take it this setup is an amp on speaker setup, similar to other nissan BOSE systems...
I was only offering the "active speaker" ideas as one alternative, it's not a goosd one, but may be cheapest if he has the active speakers avaialable to him free.Simmsled wrote:... Since what comes out is a lower level signal (the wires that are connected to your speakers right now) you need to turn those wires into RCA plugs. You do that with a high/low converter. It basically takes the speaker wires coming out of your cd player and turns them into RCA plugs. This makes it so that you can use an aftermarket amplifier in your car. This will be MUCH EASIER than trying to get a bunch of inferior Nissan "Active" speakers and amplifiers. ....
