OEM 93mm 9.0:1 compression Pistons :P
Discuss topics related to the VH41DE, VH45DE, VK45DE, and VK56DE engines.
Orphan
Car: UZZ31 Soarer
Well I'm not sure if anyone figured this out before but the VQ30DET engine has a 93mm Bore and 9.0 compression standard. I'm not quite sure about piston height etc but as its nissan I think its a pretty good bet that they would be at least similar to the VH's so they could be a good cheap option for a mild turbo project. People seem to think the VQ30DET is good for 450-500hp on standard internals so the pistons should be fine in a sub 15psi boost situation on a VH I would think.
Aus450zx
Car: 2+2 300ZX
I remember reading a thread on this, from what I recall they aren't a direct fit. and required some machining to work, and then the quelsh would be negatively affected
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
yeah we had a big discusison on this and I think the verdict is itd be much easier to have custom ones made rather than trying to retrofit the VQ.
hannibal
Car: Red Line to Glenmont
I remember plenty of discussion on the subject, but I dont recall anyone ever obtaining a set of VQ pistons for comparison.
In my mind, VQ30DET pistons are an internet myth, just like the KA20DE...
Mettler
Car: HR31 GTS-8 coupe, VH41/45 Hybrid Transplant
I asked elwesso to check out some dimensions of another factory nissan rod to suit the VQ30DET pistons, but the rod was too wimpy to be of any use.
So aftermarket rods would be needed, at which point you may as well be putting in forged pistons too.
If you want a built motor, you'll probably end up spending close to 5k to get all the additional goodies you need to make it worthwhile (fancy rings etc)
Orphan
Car: UZZ31 Soarer
:O Gah I'm behind the times haha.
Return to “VH45DE / VK45DE / VK56DE Forum”
