OE parts
vududoc
Car: drag drift autox
i got a rb20det and am running into problems finding OE parts and compatable parts. Bout all i can get is plugs @12 bucks a pop from nissan. Other than that im stuck. Things that im looking for are all tune up parts and things like OE clutch. i want to replace alot on my swap but cant find anything. can someone help? here's and example.....i heard the clutch disk froma certain year maxima and the pressure plate from a 300zx would do.....is this wrong?
mattback
Car: being a big f'ng ricer
pull off your factory clutch, and take it to a clutch place. they will work something out and figure it out.
or order a clutch from discount auto parts and match it up. then return it and say it's the wrong application.
plugs should be 1.49 each from discount auto parts. BKR7E-11's will work fine in the motor.
water pumps youre screwed, go to motorex.oil filter is a ka / vg familytiming belt you can get from nissan or from daycothermostat should be a standard nissan size. pull out the old one, take to discount, and start matching them up.
Holisticbeatz
Bribe your local Nissan parts dealer.
vududoc
thanx for the info i hope to get more. although bribing a local nissan dealer would be great if i could get the parts. the thing with that is they are my friends and they're parts data base is us specific.I assume the plugs you stated are ngk? ANY part numbers would be greatly appreciated since i dont even have even an owners manual.
