CA19DET »
https://forums.nicoclub.com/ca19det-u7344.html
Thu Nov 20, 2003 6:57 am
hey guys, i sold a buddy some Z32 30mm calipers and he put them on his 98 Premiera (98 G20 in the states) w/ some brembo rotors, he used his OE brake lines with the Z32 calipers, he had to cut the bolt that went into the caliper, and it worked.. :rolleyes
now it has held up well for over a month now, not a problem...
can i do this with my S13 coupe?? i am currently installing the PDM swaybar and poly pushing kit form whiteline and have R32 (Z32) alluminum 30mm Calipers and rotors (drilled 4 lug) and was going to put them on now as the car is down,
Will the OE S13 lines work on Z32 calipers? maybe modifying the line bolt that goes into the caliper, similar to what my P11 buddy did??
reason i ask is cause i plan on gettin the steel braided lines, but as you can guess i am outside the US and takes a lil while for them to get here, or to find somewhere that can fabricate them with teh correct fittings..
thanks..
