Odometer Toast-Cluster Replacement Questions
RocksnTwigs
Car: 90 Q45, 85 BMW 635CSi, 64.5 Mustang Convt,03 & 95 Triumph Daytonas
The analog odometer on my 90 Q has been broken for years.Both digital trip odometers work fine.
I was considering getting a replacement cluster on eBay.Before I buy I have a couple questions
First, is there an easy odo fix I should be aware of?
and second, there seems to be early and late style clusters90-92 and 93-96Are these interchangeable or should I only go with the early style?
Thanks for any help
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
As far as Im aware these arent interchangeable... And no theres no easy fix for the odometer, its best to just get a new one and set the mileage.
RocksnTwigs
I'll look for an early G50 (see how quick I learn)cluster
Thanks
elwesso
2007 BMW M Coupe
if you wnat to fix it fast, you can order just the odometer/speedo assy and swap it into your cluster..... May not be cost effective because you can get a cluster for under one benjamin.
