idriveaTTz32 »
https://forums.nicoclub.com/idriveattz32-u27432.html
Mon Oct 16, 2006 10:50 pm
9.5k seems a bit high, but i cant really make any judgements without seeing the car closely...as for the mileage YES there is an odometer issue and its generally solved one and or two ways!
Replace the speedo sensor in the transmission and usually requires replacement of the speedo head inside of the dash, i had this issue with mine where the speedo would stop working and also stop recording mileage, i tried replacing the sensor only and it seemed to only work intermitten, so i bit the bullet on the speedo head ($300-$400) and replaced it too, worked like a charm.
