I have a 1993 240sx and my odometer wasn't working so i pulled it out and messed with it a little. I have deteremined the gearing is ok, and the contacts look ok too so I figured the servo motor must be bad. I have the panel from a 1990 240sx and I was going to just swap the servo motors from the two panels. But when I got ready to do it I noticed that the motors have different numbers written on the back, but otherwise look the same. Can anyone tell me whether the odometer servo from a 1990 will work with a 1993 panel? By the way, if you can think of anything else for me to try with the orginial odometer to maybe fix it, let me know. thanks.
btw, this is also posted in the 240 tech forum, sorry if youve seen it already
