When I turned my PF on earlier, I noticed the odometer was backlit. The headlights were off, and the dimmer switch was at maximum. Even with the dimmer switch at the off setting, the odometer was backlit. With the headlights on and dimmer switch at maximum, the odometer remained backlit; with headlights on and dimmer off, the odometer is no longer lit. Is this the way it's supposed to work? I've never seen this before. This started after I replaced my rear defroster switch's main illumination bulb - it seems crazy to think that they are related somehow.
