Odometer and speedometer not working
Phantom25
Car: Nissan Maxima 2004
I have a nissan maxima 2004.
The odometer and speedometer do not work after the ABS light and brake light is on.
Please any guidance would be most appreciated.
loystock
Car: 10 Honda Pilot
97 Infiniti Q45
03 Infiniti Q45
97 Infiniti I30
06 Infiniti M35 Sports
04 G35 & 99 I30-RIP
Welcome to NICO.
Crazy things do happen when the alternator is failing or overloaded (short circuit?). So ensure battery connections are clean and tight and voltage >12.5VDC with engine off. With engine running, battery charging voltage must be >13.8 VDC (spec is 14.1-14.7VDC). Check the integrity of the wiring to/from the alternator and the battery to the fusible links.
You may have a problem with the speed sensor. So better have a free OBD II scan from Autozone and the likes, get an printout of trouble codes and report back.
darrelltstevens
Car: 2002 infiniti i35
i have solved this issue
you need the computer half of the abs pump.
45 used on ebay, or at a salvage yard.
you can find the abs pump in your car near the master cylinder,
removing the plastic potrion of the intake makes this easy.
its a gamble that it works of course, but the only alternative is a new pump for 800+
as the part that is no good is not available by itself.
you will need a star tipped driver, a 1/4" socket a small ratchet and alot of patience.
it took me (a nub home mechanic) about 2 hours to replace this.
there is a locking mechanisim on the harness connector that i broke taking off but seems to work fine all the same
id really like to express my anger at the number of posts about this specific thing that gets a "check your alternator and error codes at autozone..." replies.
that crap is NOT helpful.
car5car
Car: 04 Maxima SL
dead ABS module
