Odometer and Speedometer dont work
240sxrunner
Car: Auto and Computers
Both of them are not working it happened right after i wired in my deck like 2 days after i did it? what is wrong what wires should i check???
zachosz
Car: NONE!!!
check your fusebox
KRPSICHI3
Car: I love to race, or anything else pertaining to cars particularly Japanese sports cars.
Check you sensor on the transmission.
240sxrunner
ok i did but how can i tell if it is broken
240SXer
Car: 1995 240sx SE (2jz powered)
You checked the meter fuse?
240sxrunner
weres the meter fuse ??? passenger door?
240SXer
On mine (S14) it's on the drivers side to the left of the pedal assembly. I used to take out the meter fuse when I didnt want my miles to go up. It makes none of the gauges work. It also makes it not charge the battery for some reason.
Silvia007
Car: 93 Nissan 240SX SE Fastback
Hmm... never knew there's actually meter fuses.
singlecamhonduhkilla
Car: learning all i can about this car.. some street racing.. etc..
if its not a fuse..
my tach went out on me 4wks ago.. but come to find out that my wires that were all taped together.. were rubbing tha belts everytime i launched.. so they ended up wearing out the tape that covered them and inturn tore up the wire.. so i just got new wires connected the broken pieces and bam.. all the stuff works again.. just a thoughtjoe
