Odd wiper problem
Exar-Kun
Car: 2005 350Z
WEll..today I was in the rain, so I hit my rear wiper button, let it run twice and then hit it again...
the wiper kept going! I licked it a few more times...still going. THe only way it stops is if I cut off the car, then crank the car back up (as in, when I turn the car off, the wiper arm stops, and then wont move when I turn on the car again, unless it hit the button...then it wont stop again till I turn off the car, etc)
so I checked the motor, didnt see any odd connections or anything.
anyone have any ideas what I should look for?-chet
yellow_jacket
Car: 95 240sx
The switch may not be turning it off. You may need to get another switch.
On a side note, did Balanced figure out your overheating problem?
Exar-Kun
Car: 2005 350Z
everything is set back to stock for now...I gotta see if its OK back the way it was, if it is, we gotta get a new rad, or get my money back, etc...
I wonder how much that stupid switch is....-chet
