Odd Whistling/Humming Noise
Ron Burgundy
Car: 1999.5 Nissan Pathfinder 3.3 LE
Hopefully this is an easy answer and someone has experienced it before...
Whenever I hit the gas pedal, I hear an odd whistling/humming sound. Not like a high pitched whistle a human would produce, but more like a "ooohh" sound (kind of like creepy wind in a movie...?). When I let off the pedal, it stops.
The noise has been there since I got the car and as far as I can tell has no affect on anything what-so-ever.
Any ideas?
Pwnin O'Brien
Where is it coming from? The engine bay?
It may be a loose connection somewhere on the intake or intake tube. It may also be a bad throttle body gasket. I experienced a whistling coming from the throttle body (due to an insufficient seal at the throttle body gasket), I had to apply some RTV gasket between the throttle body and intake manifold to get rid of the whistling.
Ron Burgundy
It's hard to say...
As far as I can remember I can only hear it when I am inside the cabin, but i'll try pulling on the accelerator cable from the engine bay and see if hear anything.
What is RTV gasket?
Fisherdude
Car: 1996 Nissan Pathfinder 4x4 SE
I got the same noise, my mechanic said it was due to the replaced timing belt being a little tight but nothing to worry about.
Ron Burgundy
Interesting...
Yeah as far as I can tell it's causing no harm. I haven't got my timing belt replaced since I got the car, but I did get it close to 100,000, so its possible the previous owner got it replaced.
Thanks for the input, i'll update I discover anything new!
