odd trans problem
roadboy240sx
Car: I like Nissans
ok so our shift patern is like this
1,3,5
I-I-I
2,4,R
my 240 standard 91 ka i just got wont go into the top gears, it will go into 2,4,R just fine but if i go to put it in any of the top gears the shifter just pops back, no engagement. same thing when the car is on and runing. i have never come across this before, so any help or info would great
krash
Seems similar to a problem the 91-94 sentra guys have. If it is this same problem, then its cheaper to get a new transmission, especially since its a KA. Where are you located?
michaelgrigoras
Car: 1991 nissan 240sx
roadboy240sx wrote:ok so our shift patern is like this
1,3,5
I-I-I
2,4,R
sounds like something is wrong with the syncros
roadboy240sx
Car: I like Nissans
krash wrote:Seems similar to a problem the 91-94 sentra guys have. If it is this same problem, then its cheaper to get a new transmission, especially since its a KA. Where are you located?
that sucks i was hoping maybe it was somethign i was over looking. im in allen park michigan, basically right under detroit.
krash
Yea, on the sentras, it would keep popping out of 5th gear, and it turned out to be a synchro. I wouldn't be surprised if your synchros are bad. Go ahead and search around for a cheap 5speed trans. pretty sure its cheaper and less time consuming than a rebuild.
Patarach
Car: 240sx convertible KA-T
one of your shift linkages could be misaligned, remove front cover and check linkage positioning.
