colinm »
https://forums.nicoclub.com/colinm-u6295.html
Tue Apr 29, 2003 7:40 am
That Q I'm looking at (still), I found, has a weird transmission problem. I am going to test it and I'll fill in some details when I get back if there are any, but the transmission, no matter what shifter position it is in, is always in drive.. if it is in reverse or park it is still drive.. Not sure what gear, but the owner drove it to the shop and he said it drove fine.. Could it be possilbe that this is an easy to fix problem, and wouldn't need a transmission replace? If so I could snatch it up before he gets the transmission replaced for really cheap, and get it fixed, add a cooler, and check/fix the guides and I think come out ok.. I am hoping to get this question resolved asap as he is waiting on my word to do the transmission (and the mechanic is busy he says).
Also, is there a way to check the transmission model number without a wrench? What is the model number on the fixed transmissions? I want to know if it is the original transmission or not. I'm going to check the records real thoroughly, but I don't know how complete they are.
Thanks a bunch,Colin
