Odd Timing Problem
NismoRacer34
Car: s13 hatch (KA)
Being a victim of a thrown KA rod, I recently purchased, rebuilt, and installed a new KA. I installed a brand new timing chain kit from "Evergreen". When it came time for the first start-up, I could not get the timing right. It was way advanced and I could not get the timing to 20 degrees advanced with the distributor adjustment, so i moved it ONE notch (positive, tried it multiple times). Then it was way retarded and i again could not get it to 20 btdc with the distributor.
I spaced the distributor and got it to 20 degrees btdc but the car still feels weak and the timing seems to be still retarded. It hesitates on low rpm and has no power up high, even for a stock KA.
Has anyone had this problem before or know of something I did wrong? Any help would be awesome!
NismoRacer34
Car: s13 hatch (KA)
Nothing? Does anyone know if using an s14 engine and trans with an s13 harness would do this? I took out the crank position sensor in the bell housing but I'm pretty sure that's just a secondary sensor for the s14. Or wass that the primary pos. sensor with the 14's??
