i did try setting it that way and it ran like crap would barley rev even on boostrc1honda wrote:There was a huge thread about using a timing light with the SR. Expensive ones have trouble getting signal from the distributor less ignition and read way off, i bet if you tried to time to 25deg instead of 15deg it would run perfect. The cheap ones seem to work tho. But either way what i would is pull the valve cover, line up the CAS and line up the timing marks on the chain and the crank. Just set it mechanically. That way you know your dead on.
QFTthe converted wrote:The trick is to use a spark plug wire from the coil to the plug. The light will pick it up fine from that.
sounds pretty crazy is that from the s14 fsm? ill give it a try and see if that solves the problem i also got this emance real time ecu reader im trying to get it to work but im sure if i do get it working wouldnt i be able to view timing and set it while i view it from my computer?rc1honda wrote:
QFT
The mod has the right idea. Also i almost forgot then sometimes you have to put the engine in "timing mode".
I have never done it but i have read about it.
It sounds stupid but it's what it says to do in the FSM.
rev the car to 2,000 rpm for 2 minutes. Turn the car off unplug the TPS then rev the car to 3,000rpm 3 times and time as normal.
