atiffarooqi »
https://forums.nicoclub.com/atiffarooqi-u35866.html
Sun Mar 05, 2006 9:45 am
All of a sudden, when i start my spec v, the rpms go up normally and then drop to 700-750, almost puttering, and then rise to about 1100, where it usually idles when the engine is cold. But once the engine is warm it doesnt do this. Not only that, if the engine gets cold again , for some time it starts normally, dropping normally to 1100. But if i let the car sit for a few hours, like overnight, it does it again. The odd thing is tha tit doesnt try to die on me, it specifically drops to 700 every time. I thought maybe the clutch was rubbing against the flywheel causeing some more strain on the engine and maybe one of the release components in the clutch was ruined, but that seems not to be the case. What could this be? I would take it to a mechanic but if i did the engine would be warm and i wouldnt be able to show what happens.
Modified by atiffarooqi at 12:05 PM 3/5/2006
