odd starting problem
1989240sx
Car: 1989 240sx and 1974 duster
i was at work and i was getting ready to leave my car would not start the battery was not died i had someone try and jump start me but that did not help i went there this morning got in it and it started up just fine do you guys know what would case that problem i am think about replacing the starter so i don't have to worry about it going bad down the road
OutToWinPAHC
Car: 2015 Chevy Silverado
Nissan Skyline R33 GTS-t
Nissan Skyline R32 GTR
Nissan RB20 E46 RHD
2015 Harley Vrod Muscle
1990 Nissan Patrol
Your missing info....
If the car is a manual and always been manual you should consider the starter signal relay. Maybe remove and have the starter tested, as well as the battery. Could even be the ignition switch.
Removing the starter and battery only takes time, autozone or someone like that will test them for free.
1989240sx
where is the starter relay location at i have look but i cant seem to find it
tm1218
Car: 240sx
check the button that your clutch pedal presses in when starting the car. my rubber stopper was loose and causing that type of crap to happen. then finally it completely broke off and that is how I noticed it. also, your battery terminals could be dirty, that has caused me the same problems too. start with the easy stuff.
1989240sx
my battery terminals are good and clean and i should also told you guys that my car is automatic
OutToWinPAHC
Nissan RB20 E46 RHD
1990 Nissan Patrol
You don't have a start signal relay. You have an inhibit switch at the shifter thing, ignition switch, starter. Get the starter tested.
tm1218
Car: 240sx
oh, an automatic.
discard my statement then. lol
1989240sx
i think it is the start i was seeing if it would do it again and it would not start so i took a harmer to it and it started up just fine
