odd sounds when dirving in the vert
starion1991
Car: 1994 nissan 240sx vert
sooo. today i went out to a movie with a few frends, backed up into a parking spot and i dident know there was a tire rest there and backed up into it, Hit my exhaust and broke a hanger. so i thought no biggie, ill just get a new one welded up..
After i got out of the movie and I left I started the vert up and I herd a clicking noise coming from under the hood, went out and looked at it, the fan shroud was hitting the fan, moved it a bit and the noize stoped.. So i get back in to drive away and I notice it is a little harder to shift out of park (automatic), and as I drove away I herd a buzzing/vibrating sound comming from the auto shifter. As I drove faster It got louder and more violent. I dont know what it could be. it was dark out and dident have time to look at it on the freeway, just wondering if anyone had a problem like this on their vert, What could it be?
Thanks for the help guys
onosqv
Car: '92 240sx Vert
could be a coincidence, but then again, you backed into that tire stop hard enough to snap the exhaust hanger.
Check the motor mounts & transmission mount to see if you knocked them out of place/tore them - sounds like you somehow managed to move the entire drivetrain toward the front of the car.
starion1991
onosqv wrote:could be a coincidence, but then again, you backed into that tire stop hard enough to snap the exhaust hanger.
seems like your right, I am planning on a 5spd swap in the verry near future, what should i do? go through and do it? idk im lost right now
onosqv
Car: '92 240sx Vert
what should you do?
check what i suggested, then replace if necessary. fix your problems first before upgrading & possibly introducing new issues.
mmm240
Car: 95 Nissan 240SX KADE-T
94 Toyota Pickup
91 Mitsubishi Galant VR-4
03 Toyota Matrix XR
If your fan is hitting the shroud you have motor mount issues. you can either rid th fan clutch, rid the shroud, or get stronger motor mounts. I suggest that you rid th fan clutch and get stronger mounts
