odd sound..
stumpz
alrighty i just put in the sr in the new car this past weekend. when i cut it on.. idle little rough..i don't care bout that at the moment. got it up to temperature and all..cut it off and noticed a sound coming from the back of the engine compartment that sounds like someone blowing through a straw. i then disconnected battery cables yet it still made the constant sound.. all i know is, it has something to do w/ the heat escaping from somewhere back there because once the motor cooled it stopped.. i have yet to pinpoint where it is coming from. but should i worry about this or let it slide and see if it stops?
912.0turbo
If it sounds like bubbling then you problably have air in the cooling system.
stumpz
lol, yeah it kinda sounds like that. will it ever come out?
912.0turbo
You have to bleed the system.
