pr0tus »
https://forums.nicoclub.com/pr0tus-u38201.html
Sat Mar 11, 2006 11:22 pm
After having a very crappy night working on the 240, I'm pretty sure the smell is coming from my broken shifter boot. The boot on my transmission is broken and there is oil all over in there. If your checking yours, its the second boot you come too, after the one thats bolted on. Next time I tighten my fill/drain plugs, they are getting finger tightened. I went to drain my fluid after only changing it last weekend, and the plug stripped out on me. Then I went to add more, and the fill plug stripped out, with my 17mm wrench. I guess I'm going to have to get the square drive socket for it. I would really like to know why these things get so tight. I don't have to use nearly as much force on my s10 with nv3500 transmission. If those plugs fit I would like to use them instead of the ones in the 240, but if they get just as tight it probably wouldnt help that they are allen keys.
