Odd running problem please HELP
Ni$$@n240
Car: Currently 1995 S14 Se
Sometimes when I drive the sr it acts like the ignition is dropping one or two or all cylinders. It starts and drives daily but cruising in town at 30mph or after driving awhile and starting it back up it seems to misfire? When this happens the car jerks violently. I think the problem is heat related because it wont do it when the engine bay is cool. Almost acts like the intercooler piping popped off. Any helpful advice would be appreciated.
The problem occured even before the ecu was tuned.
It has the Q45 ignitor
Need to get a new maf because the one on it has been siliconed but has always worked.
:cry:
PyR0NiAk
Car: S13 SR W/ T2 GT3071R .86AR, JWT S4 Cams, 810cc Injectors,Z32 MAF, JWT tuned ECU 87mm 9:1 Compression CP pistons, Manley Rods
Coolant sensor = cheapest and most likely
CRyan
Car: 1997 Nissan 240SX
PyR0NiAk wrote:Coolant sensor = cheapest and most likely
Second that.
Ni$$@n240
Oh thanks guys didnt think of that. Come to think of that had to replace one on my dads ka but it didnt miss as bad as the sr is. Anyways I will try that thank you.
