XTCshri2222 »
https://forums.nicoclub.com/xtcshri2222-u34724.html
Tue Feb 26, 2008 3:57 pm
Ok, some of you read my earlyer posts, with my oil temp being on the highside, and having high oil pressure.
I have mounted the oil cooler, and have feed line running from my oil sandwich plate, question is, is it ok if i tap my oil return for the turbo, and put in a split fitting, making it so my oil return from my oil cooler would be shared with my oil return for my turbo on the drivers side of the oil pan?
Would there be any issue of pressurised oil going in on that side of the pan?
