odd noise from rear deck
soninlawscar
Car: 2012 Infiniti M37 S
2012 m37s, when you shift from park to reverse a noise like a air pump or bad speaker comes from rear deck.
soninlawscar
when the car is put in reverse, a noise from rear deck like a air pump, then stops after a min.
emm3seven
Car: 2011 Infiniti M37x w/Tech + Touring
Do you have the rear sunshade? Is it mechanical noise from the shade mechanism (which would be triggered when car is put in reverse)? That rear shade is a very very common failure.
Ilya
Please only post once.
I'm locking this thread as you posted two other threads for what sounds like the same issue (I deleted one and left this one - rear-sun-screen-t627683.html).
