Ok, about 2 months ago my car started overheating one day, and I changed the thermostat and everything was ok. I made sure to bleed the system of any air bubbles, and It's been running fine ever since. But, I was sitting In a drive through line getting food the other day and I noticed my heat gauge rising. So, I shut the car off right there, and I heard a glugging sound like all the coolant was being held back by the thermostat was now being released. I waited a couple seconds, then turned my car back on and everything was fine. My car was back to It's normal temp. And now today, while sitting In a drive through line again (hey, It's fast ok?
) My heat gauge started rising again! I shut the car off, heard the glugging, turned it back on... everything is just fine!
So, I've only noticed my car start to do this when It has been idleing for more than 5 mins. What do you guys thing is wrong with my car? Would air bubbles do this? bad fan clutch? water pump? Any help would :ylsuper thanks.
