Odd cooling issue-2003 M45
lincman90
Car: 2003 M45
On and off, with no regularity, my temp gauge will rise to nearly the top of the "normal" range, then I will hear the engine fan, then the gauge immediately dips back to the middle of the "normal" range. Any ideas as to what could be causing such an unusual problem?
JDMlove
Car: 2006 M35X
2007 HR 350Z
first Change your Coolant water.
If still exist... Check your thermostat!
seldomseen
Car: '12 Nissan Altima Coupe SR 3.5
'15 Lexus GS350 F Sport
Check the coolant level, thermostat and check if you have any air bubbles in your coolant line too.
ngtr800
Car: 2003 M45
Check for any leaks specially underneath the Intake manifold.
lincman90
Car: 2003 M45
I just discovered it. Looking for an answer to that one now!
lincman90
Car: 2003 M45
Changed the thermostat, temp gauge stays exactly where it is supposed to , now to see if the coolant on the intake manifold issue goes away with it.
candymanfb
Car: 2004 M45 - Every possible option on an M!
Check the coolant fan oil! It is something completely different from the "regular coolant".
A body shop removed the radiator, but was not aware of the uniqueness of our cars. I was pretty much overheating, and it was only after they consulted with an Infiniti dealership did they know what was wrong.
I'm unaware how to check it or add it though!
Towncivilian
2007 Nissan Altima 2.5L CVT
2012 Infiniti G37 Sedan 7A/T
The cooling fan fluid is power steering fluid. Use a synthetic ATF for better cold-weather performance and reduced operating temperatures. Its fluid reservoir looks like a power steering fluid reservoir found on other Nissan vehicles (see MA-19), so use a turkey baster to siphon the fluid from the reservoir.
