odd clutch problem
solaris22
First off I did use the search button and didn't find the solution. I was driving the other day and slowly my clutch started to give out. it started with the pedal having 2-3in of play then it slowly got bigger and bigger and the length I had to push the pedal to disengage the clutch grew more and more. I bled the clutch and still the same. I can't even get my car in gear it's so bad now. Any ideas?
Holisticbeatz
I would check the clutch master cylinder. The seal inside the clutch master cylinder could've gone bad and cause it not to funtion correctly. Also, there might be a leak somewhere in your system causing loss in clutch pedal pressure.
BuudWeizErr
It's either clutch master or slave. I had the same problem a couple months ago. It was the master.
ImportIntelligence
Car: Big turbo's :)
I just fixed a cracked clutch fork ( the one that pushes the Throw out bearing. ) Same symptoms. Big headache.
solaris22
OK I'll hit the junk yard for a new clutch master and hope I don't have to pull off my transmission. Thanks for the help guys
rsxdude
A new clutch cylinder is like 20 bucks. Why not just get a new one?
implict
BuudWeizErr wrote:It's either clutch master or slave. I had the same problem a couple months ago. It was the master.
Bingo:icesangel
solaris22
rsxdude wrote:A new clutch cylinder is like 20 bucks. Why not just get a new one?
They're free at the junk yard :D
rsxdude
Well, that explains it. haha
