Ligouri Rd »
https://forums.nicoclub.com/ligouri-rd-u1844.html
Wed Sep 21, 2005 3:44 am
Would the wastegate signal line make any difference? Klattr where are you picking up your waste gate signal?Currently I am picking up the signal directly from the compressor housing with an 18" length of reinforced vacumme line. My boost gauge is teed off of the fuel pressure regulator. My diverter (Forge, with lightest spring installed) valve is mounted fairly near the compressor as well. I know this sounds stupid, but could the diverter valve be opening a little, relieving pressure at the compressor and not sending the proper pressure to the wastegate? I know its usually discouraged to do this but, would relocating the wastegate signal to the intake manifold make any difference?
