odd ball questions
SpeedingMonk
Car: drifting, nissans, and keeping all other cars behind me
hey guyz n e 1 know...
what the weight of the stock crank, rods, pistions is?
y the forward most fan (to the frount) is not spinning the larger 1 farther back always does?
does carbon make white smoke and if not is it gasket or what?
is the carbon left behind after oil is burned?
where i can get diagrams of the air intake, engine bay, brake system, and every thing mechanical?
where i can find some "Seafoam" in new england.
what causes the tailpipe to be black.
how to tell how well ur cat. converter is working
how to / what would u use to clean ur exhaust (end of header down) take it off i assume...
where i can find a book on enginering engines +D
and a book explaining how trannys work ( auto)
PEACE u answer all this ill ask more +D
SpeedingMonk
how bought the weights ov... the rims(stock s13 se), axles and rotors are thanx
MaineExport
Car: 95 Nissan 240SX FAL fans AEM intake Hot Shot header Apexi N1 dual Exhaust VLSD ABS NX 50 shot
White smoke can be caused by a cracked head... or bad gasket.
NAPA sells Seafoam (they are all over New England at least Vermont and Maine.. not sure about western Mass)
The forward fan is electric.. it engauges at a different temp than the clutch fan. The clutch fan will spin all the time, at a slower speed when the engine is cold and faster as the engine warms and the clutch is engauged. The electric will not spin when the car is cold and not moving, it will spin slightly when air moves through it as the car moves.... and when it's thermostat kicks in it will spin.
Carbon build up can be from engine oil, but is usually due to contaminants in the fuel and oil burning off.... I'm sure there are other causes also.
howstuffworks.com has answers to your quandries... I'd go there first, as their info will be more reliable than mine... and others'
SpeedingMonk
hehe lsd whats the differances (mechanical too), applacations, weights, needs thank you
MaineExport
SpeedingMonk wrote:hehe lsd whats the differances (mechanical too), applacations, weights, needs thank you
Use the search function to answer that... there are several threads already discussing VLSD and LSD..
SpeedingMonk
thanks i appricate it
SpeedingMonk
DO u know how u would go bout testing the electric fan?
MaineExport
Find the relay.. and hardwire it temporarily. It should run when you turn the car on.... wait.. it might run constantly.. depends on when that relay gets a power supply.. but I believe it is after ignition, not constant.
SlowFiveOh
Car: drag racing, music
carbon buildup is normal and cannot be avioded, it is a byproduct of the combustion of fossil fuels. as far as cleaning out your exhaust...why? you wont gain anything from it.
white smoke is a bad headgasket, check your coolant and oil, if your coolant is brown from oil thats one sign its blown, or if there is water in your oil or you have the dreaded "milkshake" thats another sign. do not drive with a blown headgasket as it will warp heads and easily cause other problems frim having water mixing in with the oilif the smoke has a bluish tint to it, then you are burning oil, bad piston rings or valve guides would be the culprit there.
a bad converter can give off a rotten egg smell, sometimes, it may also ratlle around inside, get underneath the car and shake it to see (obviously after it has cooled off)
