odb2 > odb1
chmercer
when putting an odb2 motor into and odb1 car, what has to be switched over? i know there is a lot more lines and crap on the intake mani but is there anything else i should be looking into
95nismo240
Car: 1995 Nissan 240sx
all u need to use from the obd1 engine is the intake manifold with all the stuff attachted to it. u can use the block and the head from the obd2 engine.
Nismo_Freak
Car: 89 Nissan 240SX
TPS sensor is different between 95-96.
chmercer
upper and lower mani? or can i just switch the upper? and what about all the crap inside of it? emissions crap, coolant hoses etc anything in there need to be switched?
sorry im stupid
95nismo240
i think u have to switch both....thats what i did... but im not sure if u can just switch the upper manifold.just try to use everything u can from the obd1 engine.
AkademikONE
I have a spare KA in my garage. It's from a 92 and I'm thinking of building that and going KA-T. All I need to do is use the intake mani from my s14 and I can use the 92 Ka right? What about the transmission? Can I use the s14 transmission with the 92 block? And what's this about the s14 TPS sensor?
Thanks.
