Octane?
SilviaS14KA24DE
Car: Doriftu
Ok, my car did not come with an Owners' Manual. I want to know what the recommended Octane for teh 95 SE's are. this thread better not debate what octane is better! haha cause it's a never ending argument...
DAEDALUS
Car: 1990 Infiniti Q45
"Use unleaded premium gasoline with an octane rating of at least 91 AKI (Anti-Knock Index) number (research octane number 96).If unleaded premium gasoline is not available, unleaded regular gasoline with an octane rating of at least 87 AKI (research octane number 91) can be used.However, for maximum vehicle performance, the use of unleaded premium gasoline is recommended."
XCrunner19420
I think every car manual ive read has recomended 93 or above.
240marcuSX
Car: E34 525i
E46 M3
the 240's run best with the cheap stuff at no more than $5 at a time. :) unless your engine code ends with T.
whiterps13
Car: white LE hatch
240marcuSX wrote:the 240's run best with the cheap stuff at no more than $5 at a time. :) unless your engine code ends with T.
your joking right? also, never let your car run below 1/4 of tank. i have had bad experiences in my 300zx below 1/4.
Onizuka
Car: 91 Nissan S13 coupe SR20DET
89 Nissan S14 hatch SR20DE
If your using anything other than 87 octane on your stock motor your wasting money.
GEO
Car: 95 240sx KA-T
yeh...
240marcuSX
Car: E34 525i
E46 M3
yeah, although that is the situation in most cases with me. i use the cheap junk. i just dont buy gas from certain stations. only after turbo will i get 93.
DAEDALUS
Maybe I should have been more explicit. My first post was quoted directly from the '95 240SX FSM.
xyster
Car: '00 Prelude
I use only BP/Amoco 93 octane from high-traffic stations.
zion
Car: cars, guns, the usual
xyster wrote:I use only BP/Amoco 93 octane from high-traffic stations.
same here, Amoco white gas is the best i have used, I dont really trust anything else...
POS_S13
Car: thizzlamics
93 octane? daym in CA the highest i've seen is 91, unless you go to the track and get 110 :D
SilviaS14KA24DE
Car: Doriftu
lol yeah only 91 in ca. i've been putting in 87. i've seen no problems cause i've been putting 76 gas (no cheap ARCO or Costco gas).
Zydeco
Car: The poster formerly know as -]sTm[-HeavyHips
Well Id like to use 91 but I have bills and rent to pay so I only use 89, also I have never had a problem running below a 1/4 tank.
SilviaS14KA24DE
Car: Doriftu
me also. never had problem running 87 octan below quarter tank.
if there is something wrong with your car with or less than a quarter tank of gas, maybe something is wrong with the pressurization. Gas pump? Filter? Injectors? stuff like that
[Zero-S]
Car: Tell me whats wrong with this picture. 3 240's, only one runs.
I ran 93 in it every tank. My parents hated me, b/c I'd ***** at them everytime they'd put anything else in it (hey, if they were gonna use my car, they were gonna pay to put gas in it, dammit). But then again, my timing was advanced to the point where it would knock if I didn't run 93...
s13inutah
Car: building an awesome s13
Dude in utah we've got nothing above 91 and the price for even that is way up there
Smurf6x6
Car: 93 CA18 Coupe
The fuel in your tank is what the pump uses to lube the motor in the pump. For it to be lube it has to be completely submerged in gas, so when your running it at 1/4 tank or under it's not submerged in gas, causing the motor to run dry.
Toms240420
Car: My car
did you all realize that like 38 cents of EVERY gallon you by is TAX. 1.38 really only cost a dollar dammit.
Shawn Clark
Smurf6x6 wrote:The fuel in your tank is what the pump uses to lube the motor in the pump. For it to be lube it has to be completely submerged in gas, so when your running it at 1/4 tank or under it's not submerged in gas, causing the motor to run dry.
If it were running dry...you would not be getting any fuel and the car would soon stop running...and the fuel pump would shut off. Now perhaps running only partly submerged could increase wear, don't know, haven't looked at the geometry that closely or played with the pump. If it is pumping any fluid it should be lubricating itself unless it is poorly designed. I've always run my new vehicles from full to near empty before refilling and have yet to see that cause a problem, but I've only got about 120 K miles on each of them now.
DAEDALUS
True. The pickup hose is below the pump. Lubrication is not the issue, but temperature is. Long term, a cooler pump (or any electrical motor) will most often last longer than a hotter one. Keeping the pump submerged in gas will keep it cooler.
Smurf6x6
Car: 93 CA18 Coupe
Yah but doesn't it stay cooler though lubrication?
DAEDALUS
Cooler than without lubrication? Yes. Cooler than when submerged in gas? No. You can cool it from the inside only or from the inside and the outside. The pump generates a certain amount of heat. Varying the amount of cooling will ultimately vary the final, steady state temp of the component.
BoostFab
Car: S13cp, S13fb, S14z
I was beating the h3LL out of my stock KA motor with octane 87 for years, no problem.
when you are turbocharging your motor, you should always use highest octane your gas station offers (93)
