Octane
outcastcat
Car: none
Here's a really, really noob question i need the answer to as I look at this Egg. Whats the octane needed to run the SR20? I cant find it in online specs anywhere.
EugeneSentraSTI
Car: Nissan sentra Sti 200 (actually a sunny shaped sentra )
well how do you mean which octane?
for best performance every day?
obviously the higher the compression the better feul you should run for it not to ping id say a comp. ratio of 10-1 id o for super 100 and above?
outcastcat
Car: none
Sorry I didnt Clarify more.
What's the stock Nissan Manufacturers recommended minimum reccomended octane.
outcastcat
Car: none
I gotta read more SR20forum....Really.
Someone was running 85 pretty ok, even with cams. Unleaded regular here in wa is a minimum of 87 i think, so it whould be fine (with 92/93 being premium.)
Its not like that little egg 5spd will use THAT much gas anyway.
nametakennow
Car: '06 MINI Cooper S
87 is just fine in stock SRs, or even lightly modded ones. I ran 89 cause it's a little cleaner. With the turbo I will be running 93 for obvious reasons.
RED_DET
Vendor
2011 Infiniti G37x
Chevrolet Corvette Z06
If you plan on advancing the timing to 18-19* I would use no less than 89, I use 91 or higher in my G20 because timing is advanced.
EugeneSentraSTI
well im running the timing on 22 with 93ron but my compression is going to be between 11-11,5 what do you reccomend?
