SloMoe wrote:
Its not changing the engines makeup, its changing the fuel and timing maps to more agressive ones. If its running a high octane map and detects knock it switches to a low octane map. Higher octane fuel burns quicker, so the ECU advances timing to take advantage of it. Ive played around and re-programmed KA ECUs, and all the Nissan ECUs Ive come across have the eeprom programmed with a hi and low octane fuel and timing map.
actually, high octane fuel burns slower to prevent detonation.
i think there's more factors to how fast a fuel actually burns though. i read something about how some fuels were made specifically for high-rpm motors because they upped the burn rate with some other factor than octane.
or something. i didnt quite understand it comepletely.
any fuel engineers on this forum?
but do ka24de ecu's really have two maps?
